V1 Rear wing recommendations
WYGoblin
awesome I needed this too!! Also im not trying to steal this post at all but could you take a picture of your turbo engine for me? I'm assembling mine and need a pic for a couple points. Thanks a ton.
Not sure if this helps or not but here are some pics
Thank you all so much. My biggest issues are these. Where and what do these connect to....
The first is the evap. If your state does not do emission inspections, you can delete that line as well as the little solenoid is is connected to. Just bolt a flat plate in its place.
The second fitting runs through a check valve to brass fitting next to the MAF sensor.
Kenny123
You da man! I really can't thank everyone enough for all the help. Such a great group!
OptimizePrime
index.php
You don't have to do a catch-can here, as it doesn't do much. What you can do is put a little breather filter on #2 and cap the turbo inlet.
Kenny123
index.php
Beautiful!! I was contemplating a Catch can but I just wasn't sure that it was necessary so ill just go without for now. I appreciate the help and the picture. Makes it so much easier.
Kenny: If you want to inform yourself a little more to make a decision on the valve cover vacuum, read through this thread:
Oldchevyguy
Just my $.02. Why pay HUNDREDS of dollars for a carbon fiber wing on a, let's face it, economy hot car.??. I payed about $60 for an aluminum 2 blade one from ebay, and I think it looks great. Of course I bought the DFG uprights to make it work.
Oldchevyguy
My point for those contemplating a build, or just starting is that you dont need to spend a fortune on a rear wing. It's really more cosmetic than functional on these cars.
TheDon
Ebay, hard motion $717 shipped.
Was going to go with another ebay one that looked identical for 179 but mounts would have to be moved.
Jareth
I orded one from the same place on 3/2 and they canceled the order a few hours later because they did not have any in stock.
Perhaps they have them now.
