Day 38 9/03/2022
Hours Worked: 2.5
Total Hours: 106
(Assembly Hours: 47.5)
Tonight we installed the rear brakes and e-brake cables. The brakes are a little tricky the first time you install them, I had to watcha few videos on them just to get the pad orientation right. Methodology: First, install the black bracket that holds the brake assembly. You won't be able to get it into place with the rotors in the way. I then installed the rotor and affixed it with two lug nuts, just to keep it from flopping around as much. Next, you want to bolt in the caliper bracket and install the pads. Keep in mind, the one with the spring on the top of the pad goes to the inside (reverse of my photo). Now you can install the actual caliper, the slide studs come off with an Allen wrench. Last step is to install the braided hose and install your clip. I could only get the clip to go in over the hole/mount. After that we installed the e-brake cables. They attach easily, just route them what ever way works best. I attached the cables to the handle, then worked back to the caliper. To get the connector into the caliper, you have to work the e-brake lever on the caliper. We went to bleed the brakes/clutch and found out the Motive Unit doesn't come with caps. So, order a GM cap when you order the unit. I just assumed it came with various caps, but never checked the box until we needed to use it.
Brakes -
Note: So much trouble with pad orientation!
View attachment 35519View attachment 35520View attachment 35521
Hi All, Trying to get the rear brakes installed and could use some pictures for an 09 TC car in many angles. Also could use help on which bolts to use. There are 8 in the kit with 4 washers but not sure where everything goes. I have scoured the forum and google and still don't have what I am...
dfkitcar.com
E-Brake -
Note: I'm going to order new cables. Mine are a little rusty and I'd like to route them over the control arm.
No photos.
Is it the builders option or is there a correct way to route the parking brake cable around the rear A-arm? Above the A-arm and below the axle or below the A-arm?
dfkitcar.com
Issues to deal with:
Coolant Pump Issue - On it's way, arrives 9/08
Motive Top Cap - Ordered, arrives 9/07
