OBD has power. The scanner looks for everything a few times and then can’t connect. I currently have the fuse box put together with power and confirmed power to the PCM.Did your OBDii reader power up? Do you have 12V+ on pin 16?
Or did it power up, but not able to connect to the cars computers?
I found your “swappable electrical connectors” post…I forgot to hook up the engine to main harness connector. I had it tapped off still and thought it was not needed. I’m sure this isn’t helping some of the issues. I see the harness has a signal ground?I had a intermittent power steering box, that sometimes would stop my ability to start the engine. I ended up running the starter's purple wire into the cabin, and as long as the key was turned on, I could jump the starter using auxillary 12V+ cigarette lighter. The engine would run, but sometimes, no power steering, or gauges.
I do have the turn signal switch installed, I don’t have the HX pump plugged in though. I will try that and verify the lighting wires aren’t touching anything.I see why it won’t start. You don’t have the turn signal switch hooked up, do you? You need all components minus the lights hooked up. Maybe not the hx pump either.
make sure all the head light/tail light ends aren’t touching the frame either.
