- Rauq Goblin Guru
Evap solenoid:
Connects to this port on the throttle body:
Supercharger bypass valve:
Port with the prongs usually has like a little foam filter over it but is not really important if it's gone. Adjacent port (yellow) goes to the bottom of the bypass actuator, top of the bypass actuator (also yellow) has a short hose that goes to the supercharger housing pre-rotors, opposite port of the bypass solenoid (blue) goes to the small barb on the intake manifold buried under the fuel rails. You can also see the EVAP solenoid that you don't have in the below diagram.
The bypass solenoid can be deleted but there's not really a reason to on any supercharger-only LSJ build.
